07-17-2015 07:17 AM - edited 03-17-2019 03:40 AM
I'm doing a test using a BRI back to back. using two(2) Cisco 2800 with VIC2-2BRI NT/TE.
After I've configured, I have this error on the router Network side.
I've already checked with IOS 12.4.24YB, 15.1.3T but no success. I have the same issue.
Is there any workaround? how to Check the clock source.
Below is the output of debug isdn q921.
TestBRI#
TestBRI#cle
TestBRI#clear interface brI 0/2/0
TestBRI#
*Jul 17 14:38:44.159: ISDN BR0/2/0 Q921: Net RX <- IDREQ ri=24872 ai=127
*Jul 17 14:38:44.163: ISDN BR0/2/0 Q921: Net TX -> IDASSN ri=24872 ai=64
*Jul 17 14:38:44.175: ISDN BR0/2/0 Q921: Net RX <- SABMEp sapi=0 tei=64
*Jul 17 14:38:44.179: ISDN BR0/2/0 Q921: S4_SABME: Sending UA
*Jul 17 14:38:44.179: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/2/0, TEI 64 changed to up
*Jul 17 14:38:44.179: ISDN BR0/2/0 Q921: Net TX -> UAf sapi=0 tei=64
*Jul 17 14:38:44.199: %LINK-3-UPDOWN: Interface BRI0/2/0, changed state to up
*Jul 17 14:38:45.175: ISDN BR0/2/0 Q921: Net RX <- SABMEp sapi=0 tei=64
*Jul 17 14:38:45.175: ISDN BR0/2/0 Q921: Net TX -> UAf sapi=0 tei=64
*Jul 17 14:38:45.443: BRI0/2/0: !!!CHECK CLOCK SOURCE!!! and the interface is disabled due to Lost framing count of 41 in the past 32 msec.
*Jul 17 14:38:45.455: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/2/0, TEI 64 changed to down
*Jul 17 14:38:45.507: %LINK-3-UPDOWN: Interface BRI0/2/0, changed state to down
TestBRI#
TestBRI#
Below is the config on the routers
R1-------------- Network Side --------
network-clock-participate wic 2
isdn switch-type basic-net3
interface BRI0/2/0
no ip address
isdn protocol-emulate network
isdn tei-negotiation first-call
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
line-power
R2 ----------User Side ---
interface BRI0/2/0
no ip address
isdn point-to-point-setup
Thank you very much
Antra
07-17-2015 07:21 AM
Havent' worked on BRIs for some time, hence just wanted to try if not already
network-clock-select command on the global config and see if you can get this turned around?
