How to route all calls to the certain phone number to the specific phone Line
Sergey Lubenkov
Hi Guys,
Is it possible to route all calls to the certain phone number (333-111-2222) to the specific Line (Line 3) on the phone?
[PRI > Voice Gateway > CUCM 9.2 > ip phone]
Thank you
Deepak Mehta
Yes, it is.
If provider is sending 10 digits for example in this case 333 111 2222 then you can forward same to CUCM and if line 3 is 2222 then do a translation pattern for 333 111 2222 to 2222 .
Or you can also do translation at the gateway if you using SIP or h323 gateway and then send only internal extension to the CUCM.
Or just set the significant digits to 4 in the GW config.
In any case, yes, if it's not a DID, just configure whatever call manipulation that is required.
java
if this helps, please rate
