03-28-2013 10:45 AM - edited 03-16-2019 04:30 PM
Hi All !! Hope everyone is doing well !!!
I have a 3825 router with a few FXO ports and a couple TollFree numbers point to them. The 3825 router is configured as H323 gateway with CUCM 7.1.3 and the POTS lines are set up in a huntgroup. What I am trying to achieve is I have a couple TollFree numbers that I would like to route incoming calls to a specific extension. For example, for calls coming in on 800.111.2222 ring on extension 1111 and for calls coming in on 877.222.3333 ring on extension 2222. What's the best way to achieve this ?
Thanks all in advance !! I appreciate any inputs / suggestions !!
Danny
03-28-2013 10:47 AM
The thing is that with FXO, you cannot know if the called number was toll free or which one of the multiple pointing there, or what else, because the information is not available.
So you will have to router all calls the same way.
For better service and features, use ISDN PRI or SIP.
03-28-2013 10:57 AM
Hi Paolo !! Thanks your quick response !!
I've done this with PRI. I am trying to figure out if this can be done with POTS lines and FXO.
Thanks !!
Danny
03-28-2013 11:05 AM
It can't be done with FXO.
03-28-2013 11:33 AM
Thanks again Paolo !!!
Danny
