How to Set the CSS or Partition to None using BAT
HARIS_HUSSAIN
I tried to set the CSS of Some line using BAT Export and Insert Phone Option with Override Existing Configuration, but it always give error. I tried none  , <None> , < None >
Is there a way to set CSS to none via BAT Import Export ??
Brandon Buffin
Can you use the Bulk Administration update feature instead of importing via a file? Bulk Administration > Phones > Add/Update Lines > Update Lines. Find the DNs you want to update and set the CSS/partition as desired.
Brandon
Brandon Buffin
If you want to use the file import, it looks like if you export phone details, the CSS/partitions set to none are in the format ,None,
This should be the same format for import.
Brandon
