03-16-2013 06:37 PM - edited 03-16-2019 04:18 PM
We need help, I have call manager 8.0.3 and we need away to show all of the phones firmware in a report or can easily view without going into every phone and see there firmware. We tried RTMT which shows you that but only can show 200 phones firmware and we have more than 200 phones. We can use the switches thru cdp neighbor but that takes to long. We tried the bulk adminisrator to export that information but that didnt work. We thought of using ssh into call manager server but we dont know if that will show the phones firmware. There has to be away to view all of the phones firmware in one place.
Please help us.
Thanks.
03-16-2013 07:04 PM
Hi Horacio,
If you're running Cisco Operation Manager is possible to export that information. There's a third party application (need to buy license) that is able to do it but I really no remember the name at the moment...
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
03-16-2013 10:45 PM
Hi Horacio,
You can get this confirmed from UPLINX Software. They have tool called Phone Inventory Tool which could solve your problem.
http://www.uplinx.com/phoneinventory.htm
regds,
aman
03-16-2013 11:19 PM
Besides third party tools doesn't call manager 8 have something to use for phone firmware update?
03-16-2013 11:29 PM
Hi Horacio,
What u can do is you can go to Call Manager Administartion page-- Device---Device setings -Firmware load information.
From here u can find the firmware for respective phone models.that are not working at Defeult image
regds,
aman
08-08-2014 01:09 PM
Hi Aman,
Once you go to Call Manager Administartion page-- Device---Device setings -Firmware load information is there a way to export that information? I looked under the BULK tool and was unable to find a way to perform this task. Any tips are greatly appreciated.
Thanks!
Diana
07-28-2015 03:30 AM
using Firmware Load Information not show you the real firmware load into the phone. this only show you:
1) if in telephone itself the "text box Phone Load Name" are set with customize firmware, will report this phone as "Device Not Using Default Load".
so this report is related how CUCM is configured.
Sometimes phones have diferent firmware because error in load TFTP firmware because compatibility upgrade from factory version and new firmware set it in CUCM.
some one know thirdparty software with free license?.
07-28-2015 07:12 AM
11.x has a new feature called device load management for just that scenario:
This page allows deletion of selected unused device loads on this server for most endpoint models. Unused device loads must be deleted separately for each server in the cluster.
07-28-2015 07:52 AM
For version earlier than 11.x, you can do the following:
1. From CUCM CLI, enter the following command
show risdb query list phone file #file_name#
2. copy this file to your SFTP server
file get activelog /platform/cli/#file_name#.txt
3. Rename the file from .txt to .csv.
Once you open the CSV file, you will find a column called ActiveLoadID which list the active_load in all the registered phones in the file.
03-14-2017 10:32 AM
Thanks Mohammed
Those commands still hold true for Call Manager 11.0. Just remember to run them on the subscribers where the phones are registered and not necessarily the publisher.
I've just wasted half an afternoon figuring that out. What is worse is I've been doing this long enough to have known better and the result backups up what the device settings - firmware load information had already told me.
Best
Rich
07-28-2015 08:13 AM
thanks for sharing the new feature[+5]
regds,
aman
07-23-2013 09:06 AM
Could also try this if you’re using CUCM ver 9+
Will give you an audit/inventory of the phone's and lines configuration on the CUCM as well as the Firmware, MAC and Serial of the phones .. free is well :-)
http://blog.netpacket.co.uk/2013/06/27/cucm-phone-invetory-tool/
cheers
alexis
http://www.netpacket.co.uk/
http://www.blog.netpacket.co.uk/
11-25-2013 11:10 AM
Go to the ssh cli, and enter: "show version active".
You 'll get a list of all non-default firmwares loaded.
03-05-2020 09:37 PM
download Real time monitoring tool from your publisher
Go to device search,
Select model of phones you want to see.
Click next next next finish,
You will get the active and inactive phone loads per device.
