I have configured a Hunt Pilot with a Hunt List which points to a Line Group with some DNs as Line Group Members. Additionally i gave the affected Users the option to log-in or log-out from the Hunt Pilot by configuring the "Hunt Group Logout" Button in the corresponding Phone Button Template.
Is there a way to find out who is logged-in or logged-out from the Hunt Pilot?
Thanks for the reply ,i will have to check if the number is shared although i doubt it ,as the numbers are provisioned to the CUCM via a frontend portal that provisions all devices the same and the norm is to put a "*" in front of the device directory number. It is CUCM 10.5.
Also i did not alter the SQL query ,i just didn`t copy all output here
WOW. When I see a post like this, I think it deserves solid ratings.
+5 to Bill for always going above and beyond.
If you have not done so, please rate helpful posts!
Great post!
Thanks!!
Jan
Great info mate. Thanks fo sharing this.
Years later and this post is still really helpful and informative.
very good post really, and thank you so much for the response from you.
I have ran this command and the output was different than the actual status on the callmanager it self
I have this output sample :
Direct_Fatwa_LG 2057 f
Direct_Fatwa_LG 2134 f
Direct_Fatwa_LG 2134 t
Direct_Fatwa_LG 2094 f
if poosible what is the Device name field to add in this querry to distinquish between the DNs and devices that are sharing this DN and Drvice registration status because I care only about the registered devices and hunting status at the time of the querry run?
TIA
