563
How to synchronize CUCM Apllication User with AD or ACS server
Please letme know is that possibile Application User data with AD.
CUCM8.5.1 Versin
2 ACCEPTED SOLUTIONS
No, as previously mentioned, app users CANNOT be synched. They are manually created and only exist within the CUCM cluster DB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
You dont need ACS server for this. And No you cant integrate CUCM with ACS server.
You can use roles and permissions to achieve this..
Refer to the link below on how to assign differnet roles and permissions to user groups..
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00808c82d2.shtml
Please rate useful posts
Please rate all useful posts
5 REPLIES 5
You dony synchronize users in CUCM to AD, you import users from AD to CUCM. What do you want to do? Do you need an application user for what?
nikshah
Secondly only end users can be synched, not appln users
Does it possible to Intigrate CUCM with ACS server for Apllication User login..bcz we want to give read access to some employees..Insted creating each App User in CUCM can we intigrate with ACS server?..
java
java
Create
Recognize Your Peers
Content for Community-Ad
