700
Taylor Scott
Beginner
How to troubleshoot outgoing calls not working on call manager 7
What are the steps to check for outgoing calls not working on call manager 7? Office phones
cheers
2 REPLIES 2
Jaime Valencia
Hall of Fame Cisco Employee
Start by checking all your call routing and transformations, then move on to the GW to debug the calls.
java
if this helps, please rate
shh5455
Participant
https://<ip-address>/dna
If you have that service enabled it will tell you if your call flow logic works.  What sound do you hear when it fails?  A recording or fast busy?
Is your gateway H.323, MGCP, or SIP?
Create
Recognize Your Peers
Content for Community-Ad
