05-09-2011 05:32 AM - edited 03-16-2019 04:52 AM
HI,
How to tweak outbound CID in CME to show "Private"? Telco is saying can't control it....
Solved! Go to Solution.
05-09-2011 10:17 AM
Do you have analog or ISDN lines ?
The configuration is very different depedning on that.
05-09-2011 10:48 AM
You can configure COR so certain phones uses a DP, while other do use another.
With CME is also possible to block per-call, using a different mechanism, not dial-peer.
05-09-2011 07:08 AM
To block caller ID display on all outbound calls from a particular directory number, use the caller-id block command.
Following is the procedure how you can do this:- ( this will block the caller-id for all outbound calls)
1. enable
2. configure terminal
3. dial-peer voice tag [pots | voip]
4. clid strip
5. clid strip name
6. end
For further clarifications please refer to the following document for further clarifications
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeclid.html#wp1015121
Let me know if this helps.
Please rate if this post helps
Amit
05-09-2011 10:45 AM
I have 2 agencies setup on the same gateway and only one needs outbound CID blocked. Is it possible to block it vian DID range? Otherwise i will be per number then? Thanks,
05-09-2011 10:17 AM
05-09-2011 10:46 AM
I have ISDN lines..
05-09-2011 10:48 AM
05-09-2011 10:57 AM
Do you have any sample configuration?
05-10-2011 04:24 AM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeclid.html#wp1017101
Thanks for the nice rating, and good luck!
