03-19-2013 12:50 AM - edited 03-16-2019 04:19 PM
Dear all,
We have installed the CUCM 8.0 in the 7825-I4 Appliance server, and we prefer to install Cisco Unity on same server. Can anyone provide the detail step on how to un-install the CUCM8.0 from the 7825-I4 Appliance?
Billion thanks.
Best Regards
Ben
Solved! Go to Solution.
03-19-2013 01:03 AM
there is no uninstall procedure, you need to install Cisco unity from scratch on this server.
for the CCM, you need to take backup and restore to a new one if needed
Anas
please rate if it is helpful
03-19-2013 01:03 AM
Anas
03-19-2013 02:07 AM
Dear Aabueideh,
Thank for your support.
Would you mind providing software link to download the Unity software?
I have serached from cisco web ,
Downloads Home > Products > Voice and Unified Communications > Unified Communications Applications > Voice Mail and Unified Messaging > Cisco Unity > Cisco Unity Version 8.0 > Unity System Software-DUCS 1.2(5)HF1
Please correct me if make any mistake.
Best Regards,
Ben
03-19-2013 02:13 AM
Hi Ben,
the link is correct, but the file is a hot fix. you can find the installation under Unity System Software-8.0(3)
Anas
04-11-2013 01:50 AM
Dear Aabueideh,
Thank for your kindly support.
I have installed Unity System Software, and the previous CUCM is erased automatically.
However, the server can't auto run the downloaded software from web site. Do we need to edit the boot loader?
Best Regards.
Ben
04-11-2013 07:15 AM
Hi Ben,
Thanks for the rating
when you download image from cisco website it is not bootable. you need to convert the image to bootable image.
I use the following link to covert from non-bootable to bootable.
kindly find the below links
http://htluo.blogspot.com/2010/04/how-to-make-non-bootable-iso-image.html
Anas
please don't forget to rate the helpful posts
04-11-2013 07:23 AM
Notice the above is not supported, the supported way to get bootable media is either order it via PUT to get the physical media, or via eDelivery.
Above should only be used for labs/testing/curiosity and not for production environments.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
04-11-2013 07:29 AM
I know it is not supported from cisco, but it is working without any issues.
I will ask you a question, if you have publisher and subscriber with version 8.5 SU3. your subsriber is crashed and you need to install it from scratch, and the only media you have is 8.5 (not SU3). what shall we do in this case ?
regards
Anas
04-11-2013 07:31 AM
Download SU3 and choose the option to install a patch during install
java
04-11-2013 07:39 AM
It is an option, but change to bootable it is working even it is not supported from cisco
regards
Anas
