1352
BeefPackin
Beginner
How to unlink two lines with a shared voice mail
Hi All!
Recently found two lines sharing one voice mail, how do I disassociate the two and apply individual voice mail?
Thank You
1 ACCEPTED SOLUTION
Adam Pawlowski
VIP Advocate
If this is the standard UCM and Unity Connection setup, perhaps the mailbox for one of the two numbers has been configured with an alternate extension, resulting in them both going to the same subscriber.
If this is the case, in Unity Connection you can locate the subscriber by searching for the extensions until it shows up, maybe by using the search scope filter to expand the search to partitions until it appears:
Unfortunately if someone else set this up, they could have done any number of wacky and exciting things to reproduce a shared mailbox. Hopefully they did not.
4 REPLIES 4
Jaime Valencia
Hall of Fame Cisco Employee
You need to provide a lot more information to get help, what products are you using? CUCM? CME? CUC? other?
Is it a shared line?
java
if this helps, please rate
Nithin Eluvathingal
VIP Advisor
As Java mentioned, provide details about your setup.
Response Signature
Adam Pawlowski
VIP Advocate
BeefPackin
Beginner
  • We are using CUCM and CUC.
  • The Line is not a shared line.
Create
Recognize Your Peers
Content for Community-Ad
