How to use dial codes from provider
Fa Na
Beginner
Beginner
Hey there,
I want to use the call forwarting function which offers my provider. To acativate the call forwarting I have to tipe the code *73 into my telefon.
My problem is, that my cisco spa122 use the same code for forwarting calls, so the spa122 uses the code insteat of forwarting it to my provider.
How can i "jump" my spa122 and sent the code *73 directly to my provider?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
SPA endpoints are supported in the SMB community, might want to move your thread over there.
java
if this helps, please rate
Thank you!
Recognize Your Peers
