09-06-2007 06:39 AM - edited 03-14-2019 11:24 PM
hi, i have a 7825 server, but i dont know how to verify if the CCM is already installed on the server. How could i verify this point? i would like to configure de CCM but i each time that try to access to the CCM https://ip address/ccmadmin the page does not display and i dont know why. i already configure the server ip address.
thanks.
Solved! Go to Solution.
09-06-2007 06:46 AM
Log into the server as administrator and check the services - if CCM is installed there should be a series of Cisco services including CallManager. It should be configured as Automatic start.
You should also be able to access the admin pages via start/programs/callmanager administration
09-06-2007 07:04 AM
Also, another way to know what all is installed on the box would be to go to C:\Program Files\Common Files\Cisco\Logs and view history.log. It will let you know what all has been installed on the box.
09-06-2007 06:46 AM
09-06-2007 07:04 AM
