1412
Christian Isla
Beginner
HowTo Disable SRV Record lookup IAD2431
Anyone know how I can disable SRV record lookup on an IAD2431 running 15.0M3?  I'm using 'DNS:mysipserver-name' in my SIP-UA.  And I have 'ip host mysipserver-name x.x.x.x' in my config so that it's found.  but everytime it tries to make a call the IAD tries to do a SRV record lookup taking about 10 secs to timeout before going ahead and using the already known IP.
i've added 'ip host _sip._udp.mysipserver-name' but it's still no good, even with 'ip name-server <my ip>. I can't even enable 'ip dns server' on the IAD to act as it's own dns server.  aaarrgg !
Any suggestions would be appreciated.
ci
1 ACCEPTED SOLUTION
dkirk
Beginner
Configure an 'outbound proxy for sip' using ipv4.  This might work for you.
voice service voip
sip
outbound-proxy ipv4:x.x.x.x
3 REPLIES 3
Christian Isla
Beginner
I've also just tried this on my 2901.  SAME Thing... It tries SRV record lookup first, then after 3 attempts, it decides to finally use the IP given (or go to the hostname provided in sip-registrar)..
ci
dkirk
Beginner
voice service voip
sip
thanks,... that works out fine
Create
Recognize Your Peers
Content for Community-Ad
