Howto set a redirect number (ccme 4.1)
alig.norbert
Enthusiast
Enthusiast
Hi all,
I have the following issue:
An external, incoming call is redirected (on a IP-Phone) to 3-party voicemail. The problem is, that there is no redirect-calling nummer (should be the local internal-nr.) in the information to the voicemail.
I need the redirect-nr information for the voicemail.
Here the ephone-dn settings (2999=>voicemail):
ephone-dn 167
number 2407 no-reg primary
label number(2407)
description 0xx/xx.xx.xx
name number 7
call-forward all 2999
call-forward noan 2999 timeout 3
Here the Voice-mail dial-peer:
dial-peer voice 11 voip
description ** VOICEMAIL **
destination-pattern 2999
voice-class h323 1
session target ipv4:192.168.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Can I somehow set the redirect-nr (local) under the ephone-dn or do I have to do some changes under the BRI0/0/0?
Can anybody explain me what the "extract_redirect_orig_called_ie: IE type redirecting num none reason..."
debug output means?
Here some debug from the ISDN (Switzerland):
000254: Oct 22 17:01:25.928: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x47
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Facility i = 0x91A1130202008002010F300A0201010A0101A1028100
Protocol Profile = Remote Operations Protocol
0xA1130202008002010F300A0201010A0101A1028100
Component = Invoke component
Invoke Id = 128
Operation = Diversion Leg2
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '0819262410'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '320'
000255: Oct 22 17:01:25.928: ISDN BR0/0/1 Q931: extract_redirect_orig_called_ie: IE type redirecting num none reason 15cnt 1 plan -1 type 0 pres 1
000256: Oct 22 17:01:25.940: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8 callref = 0xC7
Channel ID i = 0x8A
Exclusive, B2
000257: Oct 22 17:01:26.152: ISDN BR0/0/1 Q931: TX -> ALERTING pd = 8 callref = 0xC7
000258: Oct 22 17:01:27.228: ISDN BR0/0/1 Q931: TX -> CONNECT pd = 8 callref = 0xC7
Channel ID i = 0x8A
Exclusive, B2
000259: Oct 22 17:01:27.296: ISDN BR0/0/1 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x47
000260: Oct 22 17:01:27.296: %ISDN-6-CONNECT: Interface BRI0/0/1:2 is now connected to 0819262410 N/A
000261: Oct 22 17:01:29.784: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x47
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
000262: Oct 22 17:01:29.784: %ISDN-6-DISCONNECT: Interface BRI0/0/1:2 disconnected from 0819262410 , call lasted 2 seco
nds
Any hints?
Thanks an regards,
Norbert
7 Replies 7
tstanik
Contributor
Contributor
The error "extract_redirect_orig_called_ie: IE type redirecting num none reason" is usually caused by incorrect isdn switch type config. Following link may help you for ephone-dn settings
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a00803e90aa.html#wp1052528
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
there may be two separate issues here. First, the message in debug isdn, it is due the telco is placing the call, with a ROP operation and the calling number twice. Not sure if this is related to the below, do all call come in this way that is a bit strange ?
Then if the voicemail is not seeing the redirecting number, can you take "debug cch323 all" to chek what the router is sending>
Hi all,
thanks for the reply.
Actually, the ISDN-debug "extract_redirect_orig_called_ie" only appears with an incoming redirected call from a mobile and it's telco related.
My workaround to solve this issue is, I put a translation redirect-called rule on the voice-port. So I got the redirect-information for the voicemail.
Greets,
Norbert
Hello Norbert, can you please post your detailed workaround? I have the same issue now with callisto express h323 (voicemail) and cme 4.2. When a external call is redirected to the voicemail then the voicemail is not receiving the redirecting id.
Here is the debug of the voicemail:
2008-04-15 18:05:42 Incoming Call. Called=999 Caller=0313001000 Redir=
2008-04-15 18:05:42 License: 2 Call(s). In use: 1 Call(s).
2008-04-15 18:05:43 Translated Numbers. Called=999 Caller=0313001000 Redir=
Normally behind the "Redir=" there is the redirecting number for the voicemail.
With CME 3.4 this worked with no problems.
Thanks for the help.
Regards Lukas
paolo bevilacqua
Hall of Fame Master
Which exact IOS do you have ?
Hello, I've got:
c2801-spservicesk9-mz.124-11.XW6.bin
Regards Lukas
Hi Lukas,
It's on a 4.1 CCME (Version 12.4(11)XJ) with
Callisto H323.
The PSTN-connection is configured as special arrangement.
voice translation-rule 40
rule 1 /\(.*\)/ /0\1/
voice translation-rule 35
rule 5 /^0\(..\)/ /20\1/
rule 10 /.*/ /2000/
voice translation-rule 200
rule 1 /.*/ /2000/ => change the ridirect nr.
voice translation-profile extension
translate calling 40
translate called 35
translate redirect-called 200
voice-class h323 1
session target ipv4:192.168.18.11
codec g711ulaw
no vad
This sample is on a 4.2 ccme (Version 12.4(11)XW5) with SIP Callisto .
voice translation-rule 30
rule 15 /^0\(..\)/ /2\1/
voice translation-rule 100
rule 10 // //
translate called 30
translate redirect-called 100
dial-peer voice 10 voip
mailbox-selection last-redirect-num
description Callisto Voice-Mail
destination-pattern 999
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
Maybe there is a better solution, but it worked for me.
Hope this help
Greets,
Norbert
Recognize Your Peers
