03-25-2008 02:06 PM - edited 03-15-2019 09:38 AM
Customer purchased HP DL380-G5 (non-mcs) that meet all of Cisco's requirements for install. Upon install, we get the error: Not Enough Physical Disk Present. 0 of 2 Present.
Tried on 5 different DL380-G5's. Used CUCM611a, CER203 and OS2003. All failed.
I found a few posts about this and tried a system erase with a SmartStart CD, but that did not fix the issue.
Any thoughts? TIA
Jon
03-27-2008 01:47 PM
Jon,
i do not understand your question. You tried to install 6.11 on 5 different machines? The DL 380 G5 is supported for 4 / 5.X and 6. Is it possible to install an older version, and upgrade later? Maybe you can ask TAC to verify bios versions.
03-27-2008 08:18 PM
Yes, I tried on several servers with the same results. Ended up being the Slot 3 vs Slot 1 issue. The raid card was in Slot 3 on the riser card whereas the Cisco OS was looking for it in Slot 1. I moved the card to Slot 1 and all is well and I can install all day long!
Jon
07-08-2008 01:59 AM
I meet another problem during install the OS4.5 or 2003.1.1 to DL380 G5 Server too. The System Fail on the RAID Setup it pop-up
The configuration of the array controller failed!
This can be caused by unexpected hardware or a hardware failure within the system.
Error code: 2822
Fatal Error
Do you have any experience on this issue? I am 100% sure the Server is same model as MCS-7835-H2. Since i already successfully install CCM5.X to this Server.
Thanks!
Daniel
07-08-2008 06:27 AM
1) When i'm installing OS 4.5 to DL380G5 i'm creating two arrays 1+0 and i don't have problem.
2) When i'm installing MPE2.0 to DL380G5 with 4 HDD i'm creating one array 1+0. Installation was succesful
08-22-2008 04:22 AM
I am having the same issue. Were you ever able to get this resolved?
Frank
08-22-2008 07:04 AM
Hi the problem is the raid controller. Open the server, move the raid controller to the onboard slot o and start the installation again. After installation you can move the card back to old slot and it works. regards, christian
