HTTP Allow List Expressway
Jaco Jacobs
Hi guys,
Has anyone successfully managed to upload a .csv file on expressway?
I am trying to add rules to http allow list but the rules do not show on inbound rules.
5 Replies 5
Yes I have done that some time ago. I’m off work for the next three days, so I don’t have access to the file to share with you. If I remember correct I copied the format of the file from the documentation. General advise, make sure you use the correct character for the separator and that you have all columns in the correct order in the header of the file.
Response Signature
Hi Roger,
Thank you for your reply.
I have followed the instructions and still no change.
I have attached the files I am using.
Are you able to see any difference?
This is the example header, this does not from what I recall match the header that I used in the past.
Url,ExpectedResult,Deployment,Description,HttpMethod
Your shared file looks to possibly have a different order of the fields and other fields.
Response Signature
This is an example of a line from the file that I've used in the past.
Url,Deployment,HttpMethods,MatchType,Description
http://<FQDN>:80/emapp/EMAppServlet,,,prefix,"EM US F5 LB"
Make sure that you save the file in UTF-8 encoding, I have a vague memory that there was something with this that I encountered when doing this.
Response Signature
