HTTP status 404- /ccmadmin/ on new install of CUCM 12.0
wfx01
hello I just finished a lengthy new install of CUCM 12.0 on ESXI 6.5.  getting a 404 not found error on /ccmadmin/showHome.do
any advice to repair the install?  i really would not like to repeat this one.
You can use the CLI command "utils service list" to show you the current status of services. I often use it to monitor the boot process of a server, especially one that seems to be slow.
5 Replies 5
Jaime Valencia
How long has it been since the install finished and you trying to access the GUI?
java
if this helps, please rate
about an hour.  so far i have tried rebooting.  and stopping and starting the tomcat service.
now it is working .. thanks i guess there is some delay built in there.
appreciate that.  i am trying to get up to speed on the cli commands.
**edit ssh works fine without additional config .. if you use the correct credentials.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/12_0_1/cucm_b_cli-reference-guide-1201.html
