11-18-2013 11:57 AM - edited 03-16-2019 08:28 PM
Using CUCM 9.1
Is there a quick and easy way to create a hunt group type set up using outside (cell phone numbers)?
The scenario will be one (person who will be ON Call) using an internal DID that is forwarded to to a cell phone of the oncall person that particular week. If no answer it would forward to the next line group of 4 members and also try their cell phones. After this it would simply repeat the entire process. So far it looks like a solution may be possible with single line reach perhaps?
Any insight would be grealy appreciated.
Dave
Solved! Go to Solution.
11-18-2013 01:41 PM
I set up something like this on CUCM 8.0 a couple of years ago.
I used the Mobile Connect feature as you suggest and it worked ok after some playing about with the timers.
The main problem was that there was no way for the remote users to log out of the hunt group. They could disable Mobile Connect using the IVR but the calls would still ring on their deskphones - if you log out of the phones (i.e. Extension Mobility) before leaving the office this problem should not occur.
The other issue was how long calls took to connect especially if a couple of people in the group did not answer. We actually recorded a message asking callers to be patient that was played when the call was first received (we were using UCCX to do the IVR and call transfer).
Hope this is of use.
11-18-2013 03:18 PM
Or you can configure the schedule for the remote destinations, but you forcefully need SNR for your scenario
11-18-2013 01:41 PM
11-18-2013 03:11 PM
CUCM 9 allows Hunt Group Login/Logout from supported mobile devices
11-18-2013 03:18 PM
11-19-2013 11:00 AM
Ok guys I've got the round robin effect I wanted with SNR and its working well. Thanks for the input! Now it just leaves my last problem of selectively or dynamically changing the order of the ringing for who is actually on call that week. Right now I'm changing the line group order
