hunt group
Hi All
How can I configure a peer hunt group so when a incoming call happen the call  go to the main ext then if is busy  or no answer can  ring to the 2nd extension if is no answer  go to the 3rd ext, then voice mail.
I am using call manager express.....
is 3 extensions......
thanks guys
I think you can choose in between peer hunt group or sequential hunt group,
    Peer Hunt Groups
In a peer hunt group, extensions ring in a round-robin order. The first extension to ring is the number in the list to the right of the last extension to ring when the pilot number was last called. Ringing proceeds in a circular manner, left to right, for the number of hops specified when the hunt group was defined.
ephone-hunt 1 peer
pilot 5601
list 5001,5002,5017,5044
final 6000
hops 3
preference 1
timeout 30
no-reg
    Sequential Hunt Groups
In a sequential hunt group, extensions always ring in the order in which they are listed, left to right, when the hunt group is defined. The first number in the list is always the first number to be tried when the pilot number is called. Maximum number of hops is not a configurable parameter for sequential hunt groups.
ephone-hunt 1 sequential
pilot 5601
list 5001,5002,50017
final 6000
preference 1
timeout 30
for more information, please see the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1171438
Please rate if this helps, by clicking the stars below.
paolo bevilacqua
Wrong forum. post in "IP telephony". You can move your post using the actions panel on the right.
Thanks Paolo
    Peer Hunt Groups
ephone-hunt 1 peer
pilot 5601
final 6000
hops 3
preference 1
timeout 30
no-reg
pilot 5601
final 6000
preference 1
timeout 30
