Hunt Groups Using Cellphone Numbers
jefferymitchell
Question for forum,
CUCM Ver. 9.1.2 Is it possible to configure a hunt group to have calls answered by a group of cellphones?
2 Accepted Solutions
Jaime Valencia
You need to use SNR to extend the call to an external device.
java
if this helps, please rate
SNR = Single Number Reach, you can review the CUCM configuration guide for your version for info on how to configure this.
java
Jaime Valencia
java
Thanks Jaime for the advice and solution.
java
