Hunt List issue
148west
Hi all
I have question regarding Hunt List. I have pool of 5 numbers and the last number forwards the call to cell phone. Question is does hunt list ignore call forwarding and move to next phone in the pool.
acampbell
YES - call forwards are ignored.
The phone will ring unless it is offhook
Then the next phone will ring. etc etc
Alex
Regards, Alex. Please rate useful posts.
thanks alex
The phone is not ringing and its not moving to the next phone. i thought its because of call forwarding. when i call the phone directly its forwarding it to the cell phone.
Exactly what are you trying to do and with what version???
Under the hunt pilot you can configure no answer and busy behaviors if the line group members fail to take the call or are busy, that can be any number you dial plan allows.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
