If you are using AAR to have your remote users dial the hunt pilot, so a call across PSTN, the hunt pilot must have a DID number, check if you have an external phone number mask set under the hunt pilot configuration. By the sounds of it you already have your AAR group prefixes correct.
You might wanna use the dialed number analyzer to check the dialplan logic.
If it helps, please rate
Please remember to rate useful posts, by clicking on the stars below.
