06-09-2016 08:00 PM - edited 03-17-2019 07:11 AM
Hello all,
All of a sudden when the router creates it's automatic dial-peer for a hunt pilot, it is adding the "$" at the end.
Because of this, the default "dial-peer hunt 0" does not work the way I want it as it is explicitly matching my hunt pilot for SRST instead of matching my other dial-peers which forward calls onto CUCM.
This never used to happen however this is now failing on a later IOS. Was there a change somewhere along IOS updates that would see this no longer working?
Solved! Go to Solution.
06-10-2016 01:47 AM
What IOS are you currently using? Yes, there are changes that happen on newer IOS. Not sure if this affected the behavior.
But you can do this to solve the problem:
1. Configure a lower preference on the SRST hunt pilot dial-peer, or leave it as preference 0
2. Configure a higher preference on the CUCM dial-peers, preference 1 - 10.
3. Configure the hunting algorithm to 2
dial-peer hunt 2
2 - Explicit preference, longest match in phone number, random selection.
06-10-2016 01:47 AM
dial-peer hunt 2
06-18-2016 05:42 PM
Hi Sreekanth,
Yes, that is what I did initially to mitigate the issue. All I know is the change must have occurred between IOS "15.1(4)M5, RELEASE SOFTWARE (fc1)" & "15.5(2)T2, RELEASE SOFTWARE (fc3)".
Not sure how to find what version it changed as I always like to red up on the changes and why etc...
