hunt pilot queue silence
eran moyal
Hello
I have problem with cucm 10.5.2-10000-5 .
sometime when I call to hunt pilot I got silnce in queue(hunt pilot) .
after we made reset to server MOH  the problem solved .
call flow:
PSTN->VG(MGCP)->Hunt pilot
I found a bug .
https://tools.cisco.com/bugsearch/bug/CSCuq94353/?referring_site=bugquickviewredir
How can I make sure that this bug?
is the issue happening with both internal and external calls ?
if its for external calls only, then make sure the right MRGL which has the MOH is assigned to the gateway.
also have a look on the bug once, where the fix is on 11.x
https://tools.cisco.com/bugsearch/bug/CSCuh15872
Venkatesh.
-Do rate helpful posts.
5 Replies 5
Venkatesh.
The problem occurs in  external calls.
please get this verified by Cisco TAC as this behavior seems to be bug as mentioned.
I have 3 server moh ,
when I disable server 1ׂ (server moh) .
The problem solved .
any idea?
Looks like the moh file is not uploaded on the server on which you disabled moh server. Upload the mob file on this server as well.
Manish
