06-29-2011 02:24 AM - edited 03-16-2019 05:41 AM
Hi everybody!
I have configured a new hunt pilot on our telephone system here.. CCUM 6.5
I have all calls ringing ok however i when the call is not answered i would like the call to be transfered to an extension's voicemail.
I have added the Forward Hunt No Answer in the Hunt Pilot settings but it keeps going to a message that says... "from a touch tone telephone, enter an extension.. bla bla bla"
See below the Hunt Pilot Settings
Anyone come across this or have any ideas?
Solved! Go to Solution.
07-14-2015 04:14 AM
sure..
add me also aryan23_19841
07-14-2015 04:15 AM
i unable to find u..
please add me..
07-14-2015 04:16 AM
send you request
add me..
07-14-2015 04:25 AM
i am onskype..
please come online..and add me..
07-14-2015 05:12 AM
thanks for your help..
issue fixed after adding codec..under voip dial-peer..
thanks
07-15-2015 03:00 AM
after adding codec g711alaw under voip dial-peer of h323 gateway..it is working fine..
now i can reach to cuc vm from pstn callers..
thanks for your all support..
specially Abdul and vikas..
07-14-2015 04:07 AM
In CUC, it's available under port group -> edit -> codec advertising. See to it G.711u is selected.
Also double verify in CUCM, device pool of gateway and voice mail port has region settings with inter/intra region (depends on both gateway and voice mail port has same or different region) relation set to G711u.
07-14-2015 04:11 AM
yes it is g711ulaw..
gateway is h323...where need to add region here?
i am using same region for all..
07-13-2015 10:20 PM
I have three analog lines:
44885050-333
44882522-222
44862522-110
these are three hunt pilot that rings group on phone when call hit these help nt pilot.
now as i assigned vm pilot to hunt pilot for busy no answer with 20 sec timeout. It is not reaching to vm as i have created three vm user in cuc and assigned these hint pilot no as alernative extension on cuc users.
i think it might by incoming caller number that is creating issue.
anyone knows hows to fix it?
07-14-2015 01:06 AM
Hi Sharma,
Please answer me this question? Do you have a proper DDI number from your service provider? If yes, is your call coming all the way to your local gateway? please use "debug isdn q931"? is your call going to CUCM Hunt Pilot? I see you used 222 for hunt pilot, what is the full DDI number which you got it from the service provider? Have you striped some of your number on the gateway?
gengads28
07-14-2015 03:47 AM
hello,
i have three fxo lines..
that coming to cucm and from cucm translating to three hunt pilot number..
44885050-333
44882522-222
44862522-110
