ā05-18-2011 03:26 AM - edited ā03-16-2019 05:01 AM
Hi Experts,
Is there any way to configure a hunt pilot number that can ring in some IP phones in addition to one or more PSTN number like mobile or land line?.
I have CUCM 7.1.5
thanks..
ā05-18-2011 04:04 AM
Natively with CUCM you can't do this, however if you use Mobile Connect you can tie a PSTN number (mobile or land line) to an internal DN. You can add the internal DN to the hunt group and when it is called the external number is also called at the same time.
Bit of a workaround, but it does work.
HTH. Barry
ā05-19-2011 12:43 AM
Take a look at the following document which will guide you through the entire process.
https://supportforums.cisco.com/docs/DOC-14629
Hope this helps.
Nitesh
PS:Please rate helpful posts
