Hunt to VM Setup
S N
Guys,
Got a doubt with Voicemail.
Scenario is:
User called an extension 1000 and after few rings when no answer / busy the call would forward to another extension 1001 and still no answer / user busy then the call should go to the Voicemail for extension 1000.
Can anyone suggest steps to achieve this scenario.
Sathya
Jaime Valencia
Hard to say, if you don't mention what you're using...
assuming CUC, that's the default behavior.
java
if this helps, please rate
Thanks Jamie. Yes its CUC. Sorry for not mentioning.
But the call goes to the forwarded extension 1001 VM not the original extension 1000 VM.
Sathya
In Unity Connection what is the following parameter set to:
  • Advanced > Conversations > “Use Last (Rather than First) Redirecting Number for Routing Incoming Call
