Hi ,
I am using HWIC-1CE1T1-PRI Interface card in cisco 2811 Router. I wants to configure this router as voice gateway.Once i configure the gateway as MGCP I am seeing the gateway is registered with CCM server.But the end points on the CCM gateway shows " Unregistered "
I wanted to whether this card HWIC-1CE1T1-PRI is supporting or not. This perticular card is not visible in the gateway end point list. I am seeing only VWIC option.
Please let me know if any idea.
Thanks & Regds,
Lalit
The CUCM releases CUCM 7.1(5) and CUCM 8.0(2) are the minimum releases supported for voice on HWIC-1CE1T1-PRI and HWIC-2CE1T1-PRI.
This release information only applies to MGCP configurations because H.323 and SIP configurations have no CUCM release dependency.
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_11xw/fmt1e1ic_voice.html
Thanks for the reply.
My CCM version is 8.0.3 and gateway is cisco 2811 Router (MGCP).
The Cisco 2811 Router is detected the HWIC-1CE1T1-PRI Interface card.
The problem i am facing is gateway is succefully registered with the CCM and when i check the end points on the CCM gateway page i saw end points are unregistered.
So i have a doubt whether HWIC-1CE1T1-PRI interface will support or not becuase when i select the interface on the ccm gateway page i am not seeing HWIC-1CE1T1-PRI interface card in the list.I saw only vwic card.
Any IOS upgrade will work on router ? Pls confirm.
Thanks & Regds,
Lalit
HWIC-1CE1T1-PRI are for data-isdn and not for voice.
For voice support you will need a VWIC2-xMFT-E1/T1
Alex
Hi Alex,
This means HWIC-1CE1T1-PRI will not support for voice.....
Do you have any supporting document....
Thanks & Regds,
Lalit
From this link:-
HWIC-1CE1T1-PRI
1 Port Channelized T1/E1 and ISDN PRI High Speed WAN Interface Card
No Voice
Alex
Hi Alex,
I have reffered the doc but no where it says it does not support voice.
Also please refere the below link.
Thanks & Regds,
Lalit
I just looked at my CUCM 8.6 and it does show as an option, if you're not getting it in the drop-down meny most likely you're not meeting the minimum CUCM requirements mentioned in your link.
EDIT: just noticed you mention you're using 8.0(3), are you sure you're properly configuring the MGCP GW in CUCM?? As mentioned in the link it does only show when it's on the motherboard.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Hi Java,
I checked in motherboard only and it does not show.
Thanks & Regds,
Lalit
Can you provide a screenshot of what you see??
java
Lalit
On a 2811 the HWIC-1CE1T1-PRI only supports data networking
Looking at the document you have reffered to
Voice on the WIC is supported on ISR-G2 platforms not ISRs like a 2811
Alex
