HWIC-4ESW is not powering up??
monasir
Hi everybody,
I've just installed 2 hwic-4esw poe cards in my cisco 2801 routers but they are not able to power up.
The cisco phones are not getting power.
i'm able to see them in my running config
if i do a sh ip interfaces brief i can see:
Fastethernet 0/1/0 - 0/1/1 - 0/1/2- 0/1/3
interface FastEthernet0/1/0
switchport trunk native vlan 130
switchport mode trunk
switchport voice vlan 240
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
These are my vlans i've created:
interface Vlan130
ip address 10.10.101.1 255.255.255.0
interface Vlan240
ip address 10.10.201.1 255.255.255.0
Sh envi:
Fan  1 OK
Fan  2 OK
ILP  Power Supply -Absent
Fan Speed Setting: Normal
sh diag:
WIC/VIC/HWIC Slot 1:
4 Port FE Switch
Base MAC Address         : 001e.1308.a52a
MAC Address block size   : 4
PCB Serial Number        : FOC11432SE9
Hardware Revision        : 6.0
Part Number              : 73-8474-06
Board Revision           : A0
Top Assy. Part Number    : 800-24193-02
Deviation Number         : 0
Fab Version              : 05
CLEI Code                : IPUIA00RAA
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Product (FRU) Number     : HWIC-4ESW
Version Identifier       : V01
Connector Type           : 01
        EEPROM format version 4
EEPROM contents (hex):
  0x00: 04 FF CF 06 00 1E 13 08 A5 2A 43 00 04 C1 8B 46
  0x10: 4F 43 31 31 34 33 32 53 45 39 40 00 56 41 06 00
  0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
  0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
  0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
  0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
  0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
4-Port HWIC-ESW Power Daughter Card:
Hardware Revision        : 4.0
Part Number              : 73-8476-04
Board Revision           : A0
Fab Version              : 03
PCB Serial Number        : FOC114832GN
RMA History              : 00
Product (FRU) Number     : ILPM-4
        CLEI Code                : IPUPACDAAA
  0x00: 04 FF 40 00 57 41 04 00 82 49 21 1C 04 42 41 30
  0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 31 34 38
  0x20: 33 32 47 4E 03 00 81 00 00 00 00 04 00 CB 86 49
  0x30: 4C 50 4D 2D 34 89 56 30 31 20 C6 8A 49 50 55 50
  0x40: 41 43 44 41 41 41 FF FF FF FF FF FF FF FF FF FF
  0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 44 C8
I also have checked both my hwic-4esw cards they have the daughter cards installed on top of them.
They are brand new
Any help with be appreciated!!
Please don't shoot the messenger!
I think this is the key bit:
Sh envi:
Fan 1 OK
Fan 2 OK
Barry Hesk
Intrinisic Network Solutions
barry
Level 7
Level 7
I think you're missing the inline power supply for the 2801 (part number PWR-2801-AC-IP=) required to make this configuration work.
Details are available on the data sheet
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b_ps5855_Products_Data_Sheet.html
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
Hi barry,
Thanks for your reply.
So that means i have to purchase 2 inline power supplies for the 2801?
You gotta be kidding me.
That will cost me extra 300 dollars.
I thought the 2801 are already provided with inline power supply
Is there a way i can check it?
Sh envi:
Fan 1 OK
Fan 2 OK
Barry Hesk
Hi, also, if you take a look at the product page, it's there: http://goo.gl/56yvn
The optional inline power support on the 4- and  9-port HWICs on the Cisco 2800/2900 and Cisco 3800/3900 series of  integrated services routers requires the use of a field-replaceable  inline power supply. (Refer to Figure 1.)
I bought mine on eBay.
G.
