I can not find CUC product in the CUCM v 8.6(2a)
ievalleyccie
While I am using CUCM V.8.6(2a) DVD to install the CUC . I could not  find the option to choose The CUC product from the list that be
supposed to include the following
Product Deployment Selection
( ) Cisco Unified Communication Manager
( ) Cisco Unity Connection
( ) Cisco Unified Communication Manager Business Edition
Any Advice?
8 Replies 8
Harmit Singh
Hi there,
The reason why you are unable to select Unity Connection is because the hardware requirements are not met. For installation issues, it's always good to mention the platform on which you are trying to install the application on. Here is a link which should help figure out whether your hardware is meeting the criteria or not for installing CUC 8.6:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
HTH,
Harmit.
if you try to install the CUC as a virtual machine, I can also recommend to download the a VmWare template from Cisco download site.
Then you are able to create new vm from it and your issue should be solved.
Martin
ievalleyccie
Martin, you mean the OVA file ?
Here is the Specs of my server and i want to install CUCM (pub,Sub) ,CUC , UCCX and CUPS
UCS C200 Server
        Processor          1 x Intel Xeon E5649 / 2.53 GHz ( 2.93 GHz ) ( 6-core )
        RAM          8 GB
        HD      450GB SAS
CUCM OVA and UCXN OVA templates are different as documented here, hence the reason you are not able to install UCXN on CUCM OVA template:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Downloads_(including_OVA/OVF_Templates)#Unified_Communications_Manager
HTH,
Chris
Chris,
Thanks for your reply but i am not expert in UCS, can you pls tell me which OVA (CUCM and CUC ) files i should use and how many UC applications i can install on my server ?
I suggest you read the docwiki pages as they provide all the details you should need:
It all depends on UCS server model and type i.e. TRC vs. spec based, deployment model, versions of UC applications you are installing, ESXi version, etc, etc.
HTH, please ratel all useful posts!
Chris
Yes, I am talking about OVA files. When you download it for CUC, UR probably able to install CUC or CUCM as well as License Server or basicaly said everything what you have available on your installation media disc. Because you meet the HW requirements.
But as Chris Deren mentioned, take a look to the wiki first.
Martin
Also, on the side note also avoid over-provisioning the UCS server. I don't think you'll be able to run all of the applications you mentioned. OVAs reserve the hardware resources I believe you'll run out of RAM and disk space.
