I can not upgrade from 6.1.2 to any other version
ibmrmunayco
Beginner
Beginner
I have to do the upgrade from 6.1.2 to CUCM CUCM 8.5 but I can not do uprgade, when I try to do the upgrade has higher versions of CUCM 6.1.x, (6.1.4 or 6.1.3) in all cases I get the errore message to show in the picture Finally try to upgrade to a release of the same vesion (6.1.2.1001-4) but the message is the same
13 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<LVL::Critical>
07/10/2012 21:00:11 appmanager.sh|CCMInstall --upgrade ERROR|<LVL::Error>
07/10/2012 21:00:11 upgrade_manager.sh|Applications upgrade failed|<LVL::Error>
07/10/2012 21:00:11 upgrade_install.sh|Cleaning up download...|<LVL::Info>
07/10/2012 21:00:11 upgrade_install.sh|Removing /common/download/6.1.2.1001-4|<LVL::Info>
07/10/2012 21:00:12 upgrade_install.sh|Cleaning up rpm_archive...|<LVL::Info>
07/10/2012 21:00:12 upgrade_install.sh|Removing /common/rpm-archive/6.1.2.1001-4|<LVL::Info>
07/10/2012 21:00:13 upgrade_install.sh|CSA Status = 0|<LVL::Debug>
07/10/2012 21:00:13 upgrade_install.sh|/etc/init.d/ciscosec start|<LVL::Info>
File UCSInstall_UCOS_SU_6.1.2.1001-4.sgn.iso
Start Time Tue Jul 10 20:24:27 PET 2012
Status
Error encountered: An unknown error occurred while accessing the upgrade file.
5 REPLIES 5
nikshah
Hi Roberto,
Can you send the install upgrade logs from RTMT, zip them and attach them here.
Niket
ibmrmunayco
Beginner
Beginner
Hi nikshah
Attach all logs attempts to upgrade to different versions
Hi Roberto,
From the log notes i can see this
07/10/2012 17:59:53 InstallWizard|Host IP0 addr for this node '172.16.10.2'|<:INFO>
07/10/2012 17:59:53 InstallWizard|Host IP0 mask for this node '255.255.255.0'|<:INFO>
07/10/2012 17:59:53 InstallWizard|Gateway for this node '172.16.10.1'|<:INFO>
validateNetworking: Default gateway name/address is invalid or gateway is not responding
Can you ensure that your gateway 172.16.10.1 is up and responding.
Niket
Giovanni Sciotti
Beginner
Beginner
I am encountering the same problem.
Did you solve? If yes, how?
Thank you.
I started with CUCM 6.0, in this version put the locale, next did upgrade to 6.2  after upgrade to 6.5 and 8.5.
Them problem was the locale.
I hope help you.
