返信
I can´t apply "timing hookflash-output" in VOICE-PORT
soportefibratel
Hi guys!
I have an VG320 with this config on port 0/1/23:
voice-port 0/1/23
cptone ES
timeouts initial 60
timeouts interdigit 60
timeouts call-disconnect 1
timeouts ringing infinity
timeouts wait-release 1
timing hookflash-in 50 0
caller-id enable
Foreign Exchange Station 0/1/23 Slot is 0, Sub-unit is 1, Port is 23
 Type of VoicePort is FXS  ON-BOARD-24FXS version 0xC3
 Operation State is DORMANT
 Administrative State is UP
 No Interface Down Failure
 Description is not set
 Noise Regeneration is enabled
 Non Linear Processing is enabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 3 dB
 Echo Cancellation is enabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 128 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 1000 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is normal
 Connection Number is not set
 Initial Time Out is set to 60 s
 Interdigit Time Out is set to 60 s
 Call Disconnect Time Out is set to 1 s
 Supervisory Disconnect Time Out is set to 750 ms
 Ringing Time Out is set to infinity
 Wait Release Time Out is set to 1 s
 Companding Type is u-law
 Region Tone is set for ES
 Analog Info Follows:
 Currently processing none
 Maintenance Mode Set to None (not in mtc mode)
 Number of signaling protocol errors are 0
 Impedance is set to 600r Ohm
 Station name None, Station number None
 Caller ID Info Follows:
 Standard ETSI
 Output attenuation is set to 14 dB
 Caller ID is transmitted after 1 ring(s)
 Translation profile (Incoming):
 Translation profile (Outgoing):
 lpcor (Incoming):
 lpcor (Outgoing):
 Voice card specific Info Follows:
 Signal Type is loopStart
 Ring Frequency is 25 Hz
 Hook Status is On Hook
 Ring Active Status is inactive
 Ring Ground Status is inactive
 Tip Ground Status is active
 Digit Duration Timing is set to 100 ms
 InterDigit Duration Timing is set to 100 ms
 Hookflash-in Timing is set to max=1000 ms, min=150 ms --> timing hookflash-in 50
 Hookflash-out Timing is set to 400 ms
 No disconnect acknowledge
 Ring Cadence is defined by CPTone Selection
 Ring Cadence are [15 30] * 100 msec
 Ringer Equivalence Number is set to 1
The port is "onhook_pend" during 40 seg!!! I need a time of 50ms. I suppose that I need the command: "timing hookflash-output 50"... but in VG320 (IOS 15.6(3)M1) this command not appers
VG320(config-voiceport)#timing ?
digit DTMF digit duration in milliseconds
hookflash-in Hookflash input duration in milliseconds
inter-digit DTMF inter-digit duration in milliseconds
PLEASE: ANY IDEA!?
THANKS IN ADVANCE!
0件の返信0
