I cannot set list on ephone-hunt 4 longest-idle CME 7.1
I have CME 7.1 with B-ACD , by means of the option "dial 0"  I want to reach a FAX that is connected to FXS port.
when I wan to set  ephone-hunt 4 I received the following error "Number 109 is not a normal ephone-dn or a *"
I notice that the problem is because the 109 extension is not defined as ephone-dn; but this extension is associated to
voice port 0/3/0.
all the option of B.ACD work fine, the only problem is with this FXS extension
  How do I avoid this issue???
Router(config-ephone-hunt)#list 109
Number 109 is not a normal ephone-dn or a *.  ----------------> why ?????
voice-port 0/3/0
cptone MX
timeouts call-disconnect 3
timeouts wait-release 3
description FAX 109
dial-peer voice 20 pots
description FAX 109
destination-pattern 109
port 0/3/0
VoIP-Tech
The list will cary an ephone-dn. Therefore instead of a destination pattern, you can create an ephone-dn of 109 with desired options.
I had already tried with ephone-dn  , but ephone-dn must be associated with ephone but for this extension (109) I have a FXS port
it does not work with ephone-dn
regards
