i cannot turn on the Voice Feedback feature on cisco IpPhone 8841 8861 series
Hk15
Hi all,
i need to enable the voice feedback on the accessibility settings and unfortunatly the buttons is locked and it s impossible to activate it .
we are using cisco ip phone 8841 and 8861 running on firmware sip88xx.12-5-1SR1-4 and cucm version: 10.5.2.
someone can help me in this concern please ?
Many thanks  in advance
9 Replies 9
Jaime Valencia
Is the settings access set to enabled?
java
if this helps, please rate
hi Jaime ,
yes , "Settings access" is enabled on the phone.
a
Ratheesh Kumar
Hi there
How about by pushing the Select button three times ?
Enable Voice Feedback from Accessibility
You can enable or disable the Voice Feedback feature by pushing the Select button on the Navigation ring three times. But you can also access this feature from the Accessibility setting on your phone.
With Voice Feedback enabled, you press your Softkey buttons twice to use or configure a feature.
Procedure
Step 1
Press Applications .
Step 2
Select Accessibility > Voice Feedback.
Step 3
Select On to enable the feature.
Step 4
Select Exit twice to save your settings and return to Applications.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Hi Rath
nothing happens when i push the Select button three times.
the softkey to enable the voice feedbzack is grayed in Applications ---> Accessibility
a
Have you solved the issue. I am having the same issue . If you solved it please let us know
hi,
yes , on which version the cucm is running ?
not supported on 10.5 .
We are using CUCM version 11.5
what could be the best suitable answer for this question?
. An engineer is scheduling a conference in Cisco TMS. One endpoint can be dialled only by
using a public IP address. Which menu path should be the engineer navigate, to add this user
to be the conference booking?
a. Add participants > Dial In > IP video
b. Add participants > External > Dial out > ISDN H.320
c. Add participants > External > Dial in > Ip Video
d. Add participants > External > Dial in > ISDN H.320
e. Add participants > External > Dial out > Ip Video
Hi there,
Can someone help me with these questions?
A conference that was booked by Cisco TMS is currently in session. The user ask you to bring
another endpoint into the conference. Which two menu path can you navigate to enable
Cisco TMS to add the endpoint? (Choose two)
a. Booking > List Conference > Add Participant Dropdown
b. Monitoring > Conference Control Center > Conference > Add Participants
c. Booking > Ad Hoc Booking > Select Endpoint > Automatic Call Launch
d. Monitoring > Conference Control Center > Drag and Drop Endpoint from Endpoint
Folder
e. Booking > List Conference > Edit Conference > Add Participant
Two single camera endpoints are in a video call together. They are both registered to a Cisco
Expressway. One camera is presenting using duo video. Which two pieces of information can
the engineer deduce? (Choose two)
a. One video steam total is in the call
b. This call can be interworked with SIP and H.323
c. The H.263 protocol is in use
d. Two video streams total are in the call
e. This call cannot be interworked with SIP and H.323
An engineer needs to configure Cisco TMS version 14 to deploy Cisco Telepresence System
EX series endpoints and register to Cisco Expressway. When a user uses the touch screen at
first boot, the endpoints should automatically configure after the user enters some basic
information and a username and password. To fulfil these requirements, which two items
should be the engineer configure? (choose two)
a. User Import Settings
b. Cisco TMSBA
c. User Templates
d. Cisco TMS Agent
e. Cisco Expressway Auto-Registration
 An engineer is configuring Optimal Definition Profile settings on a Cisco TelePresence
endpoint. Which two Cisco best practices must be considered? (Choose two)
a. Set quality to motion
b. Should be set to high in poor lightning environment
c. Set quality to sharpness
d. Controls the maximum bandwidth that can be allowed for calls
e. Should be normal in poor lighting environment
When implementing video design SCCP-based endpoints, for which feature must an
engineer be aware of limited support?
a. Ad-hoc video conferences
b. Simultaneous audio/video mute
c. Video codec renegotiation
d. Video call hold
. A customer has Auto Answer disable on all points which is triggering several alerts in TMS.
To which location does the engineer navigate to prevent this issue from happening globally?
a. Administrative Tools > TMS Ticketing > Manage Ticket Notifications
b. Portal > Reporting > Ticket Notification > Error Levels
c. Administrative Tools > Configuration > Manage Ticket Error Levels
d. Administrative Tools > Systems > Provisioning
A user needs to register a Cisco TelePresence EX90 to Cisco Unified Communication
Manager. Autoregistration is disabled. What is the fastest way to register the endpoint?
a. Add the IP address to Cisco Communication Manager, then enable autoprovisioning
b. Add the IP address to Cisco Communication Manager, then turn on autoregistration
c. Add the MAC address to Cisco Communication Manager, then configure the Cisco
TelePresence EX90 thrugh WebAdmin
d. Add the MAC address to Cisco Communication Manager, then enable
autoprovisioning
e. Add the MAC address to Cisco Communication Manager, then use the provisioning
wizard on the Cisco TelePresence EX90
