I got a problem with CUE Network Module
tiger14032010
Dear all,
I have been configure the Network Enhance Module Cisco Unity Express. I can't connect to network module, I try to ping the Ip Address, it did not work. Then I try to plug and play the network into Router again, It work fine, after I configure AA about 3 days, it work fine but I couldn't connect to network module again by telnet, about 2 days. I can ping and connect to the network module by HTTP. I have to reload router 2 times but I can't connect to the network module. I use the command line "Service-module integrate-service-module 1/0 session" and have a message "try 10.0.0.21, 2067.. Open" then I press Enter, it does'nt work.
Thanks and regrads
7 Replies 7
change333
I am also experiencing the same problem. However, the CUE is accessible via GUI. I noticed there the TTY speed is little odd.
      1    1 AUX   9600/9600  -    -      -    -    -     0      0    0/0      -
    131  131 TTY 115200/115200-    -      -    -    -     7      0    0/0      -
Thanks Change333.
But my problem doesn't same it.
You must connect to the service-engine which should appear in the sh ip int br output.
So the command should be service-module integrated-service-engine 1/0 session
Regards.
Alain.
CUE Network Module was work fine, I had configure the Auto Attandent, But I couldn't connect to the CUE Network Modoule about 2 days. I try to test it, I
can ping and login the CUE Network moudle by HTTP, but I didn't telnet by Command line "Service-module integrated-service-engine 1/0 session"
I think the hardware had problem. so Somebody get same my problem.
Thanks and Regards
Like on terminal server sometime the line is stuck for any reason ...
Check the line busy (with *)  and try to clear it .
Router#sh line
   Tty Line Typ     Tx/Rx    A Modem  Roty AccO AccI  Uses  Noise Overruns  Int
*     0    0 CTY              -    -      -    -    -     8      2    0/0      -
*    66   66 TTY   9600/9600  -    -      -    -    -     9      0    0/0      -
*   514  514 VTY              -    -      -    -    -     8      0    0/0      -
    515  515 VTY              -    -      -    -    -     1      0    0/0      -
    516  516 VTY              -    -      -    -    -     0      0    0/0      -
    517  517 VTY              -    -      -    -    -     0      0    0/0      -
    518  518 VTY              -    -      -    -    -     0      0    0/0      -
Line(s) not in async mode -or- with no hardware support:
2-65, 67-513
router#clear line 514
Anybody got same LongPham Problem. Can't connect to CUE from the Cisco Router.
Hi All
Anybody got same problem? Please, Can you give me the solution?
