I need to replicate Avaya's "abbreviated dial group" function on CUCM 8.5
Rew Waltman
I'm running CUCM 8.5 and have just converted from Avaya definity. We used "abbreviated dial groups" to allow a group of stations to share the same speed dials numbers.
Is there a way to replicate it in CUCM? I can put the SD buttons on each phone but it is time consuming.
Rew
Jaime Valencia
Just create a set of translation patterns everyone can reach and tell them what to dial. You might be able to use the same numbering plan, if you want the SD to appear on the actual phone, there's no no way around that other than to do the config and maintain manually on each phone.
I'd go the TP way, easier and faster.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
It's disappointing that cisco doesn't have a simple answer to this basic feature. I
You cannot expect to have a 1:1 parity of features when migrating from one system to another, if you want this to be considered for a future release, engage your AM and submit a PER.
java
java
