04-18-2011 05:56 PM - edited 03-16-2019 04:34 AM
I have a request to run a report to show all users with International dial access.I have created a CSS for international dial access but I cannot see where i can run this report from?
CAR does not give me the report i need it shows call details on what calls are made time and date etc but not basic user information,
Like who has international dial access based on the CSS i have created.
Can i run a report on users who are in a CSS?
Solved! Go to Solution.
04-20-2011 02:19 AM
Jay,
Really your looking at cross referencing two different things, Users can have departments but don't have CSS. Phones/UDP have CSS but don't have departments.
In CuCM 8 on the menu line there should be a Bulk Administration menu, that's BAT.
The way I would suggest you do this is export all detail as described earlier, sort the spreadsheet to find only the CSS you want then you the alerting name or userid to get the user details and look up the department using Excel referencing another table.
Craig
04-19-2011 04:23 AM
There is no reporting on that unless you go directly to the DB to run some queries to find out who has it configured.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-19-2011 04:45 AM
You can tell what devices are using the Dependency Records, which will give a simple 'report'. You can drill down and get a list of phones or user profiles using that CSS.
Dependency records are found by looking up the CSS your interested in the top right hand side of your screen pull down the related links.
If this doesn't meet your need can tell me more about the 'users' your looking up, do you mean real phones or extension mobility profiles I can help you write an SQL lookup that will dump everything you need.
Please rate helpful posts.
Craig
04-19-2011 04:56 AM
Also a different approach would be to use a BAT export to create a CSV file.
Bulk Administration>Phones>Export Phones>
Then you have options of all details or filtering, as I don't know how you have your CSS's configured (blocking or not) try exporting All Details and opening the resulting file in Open Office or Excel 2007 or better. Excel 2003 has a column limit that may cause your data to be truncated.
Hope this helps,
Craig
(PLEASE RATE HELPFUL POSTS)
04-19-2011 09:10 PM
Thanks for getting back to me Craig,
First thing was that I tried the BAT tool but I ran into few problems, we are running CCM8 on Linux backend and the BAT application is not visible, I’m logged in as Admin but cannot see this?
So it tried the dependency records for the CSS and that worked but again it only shows the Directory Number, Partition and Device.
What I’m trying to get is a report which shows what users in a department have international dial access, now I have run the Dependency for the CSS which is assigned for international dial access but I cannot cross reference that with the user in the department?
Seems like a lot of work to get one report?
Cheers Jay
04-20-2011 02:19 AM
Jay,
Craig
04-20-2011 09:29 PM
HI Craig,
Yeah i have done this, i thought there could be a easier way. Thanks for your time and effort.
Cheers Jay
