10-10-2012 08:50 AM - edited 03-16-2019 01:37 PM
Hi all,
I would like to know if I can change the administration password on the call manager, Is the user I define at the instalation, I've not chaged it for a long log time, I would like to know what could be worng at the time I chage it.
Which services will be down,
Telephones will ge unregisteres.
Al the publisher will reject eachother.
Have u' had experienced any problemas while changing thw Admins password.?
I already know the following services will be logged with the new password.
* Call Manager Web Administration.
* SSH2 CLI Administration.
* Realtiame Monitoring Tool, (yes I use the user Admin to log in it).
Any advice?
Reggards.
Solved! Go to Solution.
10-10-2012 09:34 AM
Hello Juan
Take a look on this doc:
https://supportforums.cisco.com/docs/DOC-16780
Rate this if helps!
Leonardo Santana
10-10-2012 09:34 AM
Hello Juan
Rate this if helps!
Leonardo Santana
11-02-2012 09:14 AM
Thans Leonardo,
This was very helpful.
