09-19-2011 10:50 AM - edited 03-16-2019 07:04 AM
In my call center our Customer Care representative gives a call to customer and explanin about our product..in return the customers call back on this same numbers to avoid 800 call charges we do provide 800 call number facility so i want the incoming calls of landline and mobile numbers on 4 Extensions(2454,2818,2684,2547) only to be show busy .and for company internal calls to be allowed with similar range of extensions. if their is any Dial Peer configuaration can anybody write the Dialpeers configuaration for this Extension numbers(DID) Thanks in advance.i am using cucm 7.1.3 and H.323 Gateway.
Any Earliest Solutions highly appreciated.
Solved! Go to Solution.
09-19-2011 03:55 PM
Sample config.
Please use your own rule number and add to an existing VOIP dial peer that points to the CUCM
voice translation-rule 101
rule 1 reject /2454/
rule 2 reject /2818/
rule 3 reject /2684/
rule 4 reject /2547/
voice translation-profile BUSY_OUT
translate called 101
dial-peer voice 101 voip
call-block translation-profile incoming BUSY_OUT
call-block disconnect-cause incoming user-busy
incoming called-number .
Alex
09-19-2011 04:35 PM
hi
you can use the solution suggested by Aex but i think if you are using pstn line/tdm like pri t1/e1 you need to have the above dial peer to be pots rather than voip
or you can still use the voip dial peer but apply the reject translation profile in the outboud direction toward cucm
the other way is to provide the voice gateway diffrent CSS that has access to translation patten in iffretn partition with the same numbers above and the translation set to block
up to you if you want it to be blocked on the gateway or cucm level
hope this help
09-19-2011 03:55 PM
Sample config.
Alex
09-19-2011 04:35 PM
hi
hope this help
09-20-2011 12:34 AM
Hi What about my Company Internal Call with 800 users for this four 4 Extensions(2454,2818,2684,2547) will they be able to receive calls of this users
09-20-2011 12:11 AM
Thanks very much guys i will try this solution i really appreciate your quick response keep going
