12-14-2018 12:13 PM - edited 03-17-2019 01:50 PM
Is there a way to program multiple users (100+) IP phones over a network to program DND for available softkey?
I do not believe our PBX supports this and I would need to do so.
We use the CP-7841
12-14-2018 03:20 PM
Create a softkey template for your needs then use the Bulk Admin tool to change your phones.
Fairly straight forward process.
12-16-2018 11:42 PM
Yes you can change, create a softkey template.
Then select BAT- > Phones- > Update Phones - > Query. Then select the device type and click next.
Then select the softkey template you want.
Run the job.
Thanks & Regards
Aman
12-17-2018 12:34 AM
