Walkthrough Wednesdays
1881
chrysostomos1980
Contributor
Identify Incoming calls in CDR
Is it possible to Mark incoming calls in the cdrs?
Just to show the calling number what type is: National , International, Local
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
2 ACCEPTED SOLUTIONS
Sergey Pitutin
Beginner
You will need a call accounting system working with your CDR format. For example, marking incoming calls with color depending on calling party number using Tariscope call accounting system:
Yes Imagicle Billy Blue does what you need
Carlo
Please rate all helpful posts "The more you help the more you learn"
9 REPLIES 9
paolo bevilacqua
Hall of Fame Master
You need to be specific.
GW CDRs? CM CDRs?
Paolo
The cdrs for CUCM
Actual the client wants when he opens teh cdrs then to see which iincoming calls are international
Then I don't know the answer, sorry.
Do you have something else to propose?
Is any other solution for the needs that i desrcibed above?
Sergey Pitutin
Beginner
Hi Sergey
Thank you for your answer
Most propably the same with billing blue right?
I don't know billing you mentioned, but I think yes.
Carlo
MTS (mtsint.com) have a good solution for Cisco Call Manager and CDR analysis.
You can see the solution in http://mtsint.com/call-accounting-for-cisco/
Content for Community-Ad
Spotlight Awards 2021
