igmp/multicast (catalyst 4507 and 3560)
cascolibre
I have a core switch catalyst 4507 and edge switch as catalyst 3560.I need the igmp configuration on the switches. I think I need activate multicast on core switch then activate on edge switch.They will be used for IPTV system.
Please help me asap.
AJAZ NAWAZ
Level 5
Level 5
L3,
I think I need a igmp snoop configuration for edge swirch. right?
Yes correct. Make sure you understand this document:
http://www.cisco.com/warp/public/473/22.html
If you have any further qtns pls do not hesitate to get back to us.
hth,
Ajaz
pls rate the post if it helps
