03-11-2013 09:59 AM - edited 03-16-2019 04:11 PM
If I have a two button desk phone - 7945G - and two lines and I want to ignore one of them for a time is there a way to do that?
e.g. suppose my second line is shared with four other people/phones. Now I am on my lunch break and I want my phone to
not be notified if there is a call to the extension on that second line. Is there a way I can turn it off at the phone if the Admin
give me the permission? THanks.
03-11-2013 10:30 AM
Your options would be as following:
1. un-associate the line from the DN, need admin access
2. change the ring setting to DISABLE, you can do that from ccmuser page assuming the Ring Settings enterprise parameter is set to True.
HTH,
Chris
03-11-2013 10:57 AM
hi,
use DnD button (don't disturbe)
Anas
please rate if it is helpful
Sent from Cisco Technical Support Android App
03-11-2013 11:15 AM
DND silences all lines on the phone, not just a single line and call still come in, it just silences the ringer.
Chris
