Cisco Community Designated VIP Class of 2020
2978
Highlighted
ILS Configuration issue CUCM 9.1.1
I have configured ILS on two CUCM 9.1.1 clusters (Hub and Spoke). They authenticate using password (not with certificate). The spoke seems to have registered to the hub. However, the clusters do not seem to see each other.
  Advanced Features -> ILS Configuration ->ILS Clusters and Directory URI Imported Catalogs (bottom section ) is emty on Spoke and on Hub this section contains only Hub cluster.
On the Hub i can see following info:
Found 1 hub cluster(s), 0 spoke cluster(s), and 0 directory URI imported catalog(s).
On the Spoke I can see follwoing info:
Found 0 hub cluster(s), 0 spoke cluster(s), and 0 directory URI imported catalog(s).
The clusters have uniques cluster IDs in Enterprise Parameters.
The tomcat-trust certificates have been exchanged (although this step was not necessary, since I am using password authentication.
If anyone has any ideas, please help.
Everyone's tags (5)
18 REPLIES 18
Engager
Hi 1-Is this configuration
1-Is this configuration for URI dialing?.
2- Cancel registeration , specify HUB  and specify password then save a page will appear registeration server press ok without adding any ip address . Then go the other Spoke and type same password , after that a page will appear type the IP address of your HUB.
3- Go to services on each cusm and restart intercluster domain lookup service.CUCM - servicabilty - Services
Please rate all useful information
Engager
HIDid you configure SIP trunk
HI
Did you configure SIP trunk between two CUCMs "HUB&SPoke"?.Device-Trunk
Did you configure a SIP route pattern?. call routeing-sip route pattern.
Did you configure intercluster Directory URI  configuration?.call routing- intercluster Directory URI -intercluster Directory URI.
please rate all useful information.
Engager
HI1-Can you answer the above
HI
1-Can you answer the above questions?.
2- Status on HUB and spoke on the bottom of page of ils configuration "ILS clusters and directory
URI  Imported ?. I need to see the status , if the integration is ok you have to see up to date .
please rate all useful informration
Hi,1. Yes the SIP trunk is
1. Yes the SIP trunk is configured with the SIP profile including the FQDN parameter.
2. Yes. The SIP route pattern is configured.
    a) On HUB it is "br.com" pointing to SIP trunk to Spoke
    b) On spoke it is "hq.com" pointing to SIP trunk to HUB
3. The option Intercluster Directory URI Configuration (with Exchange Directory URI Catalogs with Remote Clusters) iis checked on both HUb and spoke:
    a) On HUB it is "hq.com"
    b) On spoke it is "br.com"
I wll provide you the scrrenshots rearding ypur next next question.
Thanks, Regards
Engager
HiCan you try the below:
Can you try the below:-
1)hq.route
2)br.route
Go to enterprise paramater on each CUCM
and change cluster ID
1)HQ.com
2)BR.com
and do again the ILS  , then restart the services .
Please rate all useful infromation
Hi,I have attached the
I have attached the screentshots.
1. Do you want me to change SIP troute patterns to hq.route and br.route?
2.I will try it with upper case.
Engager
HiYes , try to change SIP
Yes , try to change SIP route pattern to hq.route and br.route?. And change enterprise parameteres on each cucm to HQ.com and BR.com any name as you wish.To change enterprise parameters go to cucm - system - enterprise parameters - cluster id " chnage it". After that do again ILS.
Note: This is after ILS ok on SIP Trunk check that you enable under outgoing calls -calling and connected party Info format " select Deliver URI and DN in connected party , if available ".
please rate all useful information .
Engager
Hi1- Based on your attached
1- Based on your attached file.
2- Please change the password on ILS to do again the ILS , then restart the services on each CUCM and wait for some time . Did you get an error that registering is take a long time ???.
Hi,I have done the changes
I have done the changes and verified the SIP trunks.
Everything it OK - by the book.
Changed the password I do not get the error message about the registration taking too long. Spoke is registerd after 15 seconds.
Informational MessageStatus: Ready
Informational MessageFound 0 hub cluster(s), 0 spoke cluster(s), and 0 directory URI imported catalog(s).
Informational MessageRegistered Successfully.
Engager
HiSo your issue solved ??,
So your issue solved ??, can you share with me same output which you sent before regarding status on ,docx .
Hi,The issue is not solved.I
I get these status messages, but still hub sees 0 spokes and spoke sees no hub in the status below.
Although as you can see the registration statsus of the spoke to hub seems OK.
Hall of Fame Cisco Employee
I have it working in my lab
I have it working in my lab configuring each server as a HUB, I got 10.0 and 10.5 and it works just fine. Just make sure the SIP route pattern exactly matches the RHS of the URIs, and that you configure the same as the advertised route string.
java
if this helps, please rate
hi,There is one more thing
hi,
There is one more thing that might be of importance.
Since it is a lab environment, the Spoke cliuster has not been installed from scratch but it is a copy of the HUB CUCM VM (hostanme and IP address have been changed and certificates regenrated)
Do you think it can be causing such problems? (some sort of identity mismatch)
I am currently reinstalling the clusters.
Beginner
Hi Piotr,
Hi Piotr,
I see that no answer take into account the point that you have one copied VM. I got the same issue with a different version (11.0) and we have in common this point of copied VM. The CLI command "utils ils showpeerinfo" give the same "Peer Id" for the two machines. I think it can cause a problem in synchronization.
Sorry to be 2 years late, but it can help somebody else...
Content for Community-Ad
FusionCharts will render here
