Community Helping Community
453
Participant
IM&P federation
I want to be able to federate 2 separate CUCM clusters (different companies), so that IM&P users from each cluster can see each others presence status, make calls and do screen share, in other words act as if they are one cluster. This will be across a private MPLS link and not across internet.
I am wondering the best way to achieve this.
will it be via conditional forwarding entries on the DNS pointing to eachothers DNS servers as well as the usual SRV records?
Also is there a way to implicitly allow all the contacts from each company to be populated rather than having to find contact, which then sends a request per user for that user to have to "friend them"
4 REPLIES 4
Highlighted
VIP Mentor
Re: IM&P federation
I think your best bet is to use internal XMPP federation. If you have expressway deployed, then the recommended approach will be to use XMPP federation via expressway.
Here is the link on how to setup XMPP federation.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/interdomain_federation/10_5_1/CUP0_BK_I07B7052_00_integration-guide-interdomain-federation-105/CUP0_BK_I07B7052_00_integration-guide-interdomain-federation-105_chapter_01010.html
With XMPP federation, there is no way to auto-populate contact. Infact you cant find them either you will have to manually add these contacts.
Please rate all useful posts
Hall of Fame Cisco Employee
Re: IM&P federation
If they're using the same domain, you can configure an inter-cluster peer and that is fairly easy to setup.
java
if this helps, please rate
Participant
Re: IM
Unfortunately they are 2 separate domains
Beginner
Re: IM&P federation
Have you managed to implement this?
I have a similar scenario and implemented XMPP federetation between two IM&P  servers 11.5.1 SU5. Chat its working but presence status only appear after chat is initiated and just for a couple of minutes. Any  suggestions?
MC
Content for Community-Ad
FusionCharts will render here
