is turning off IM&P trace under IMP serviceability -services-IMP services-XCP services are service affective?
Hi, we are having alerts on IMP 10.5 about VM memory :
" Message: VOS: Virtual Memory Used 91% Threshold 90%" too often. I saw there is bug related to this
"IMP: jabberd process memory leak/Cores when XCP trace at non-default.
CSCuq31057 " and in my case jabberd taking most memory with XCP config manager
Right now trace level for all XCP services is set up to Info and its on. I want to try to turn it off and see if it will help to solve this problem. If I trun it off :
1 will it affect to running jabber services?
2 do i need to restart XCP router to make this affect ?
Thank you
