07-27-2015 01:48 PM - edited 03-17-2019 03:47 AM
Please find the attached screenshot ...during IM&P installation i am encountering error.
07-27-2015 02:37 PM
Hi Siva,
ARe you using the correct OVA Template on the ESXi 5.5 ?
It may be the Installation doesn't like the V-NIC, may be try using VMXNET-3 and see if it helps
07-27-2015 03:57 PM
I am using the correct OVA...it comes with BE6K bundle latest OVA template..
07-27-2015 11:18 PM
I think the first thing to do is to download the right OVA such as cucm_im_p_10.5_vmv7_v1.1.ova
Also, is this a fresh installation or are you trying to rerun an installation on existing VM? The reason that the messages are saying 'the module 'x' is already installed'.
I suggest to delete the VM and start with new installation.
07-28-2015 07:34 AM
Hi Siva,
As u have mentioned that u have got BE6K, then, u have got IM&P pre-installed .U need to just Power ON and proceed with installation.
In case ,if u are deploying separate OVA, then, u need to use cucm_im_p_10.5_vmv8_v1.0 which u can get from datastore.
regds,
aman
07-30-2015 03:57 AM
Problem has been resolved...installed multiple time..
07-30-2015 04:31 AM
Great News. Don't forget to rate useful posts.
07-27-2015 06:07 PM
Also just make sure that you are using the version that is compatible with that of the CUCM, else it will never install and the err message is ambiguous.
Secondly, i shall recommend to download the OVA compatible with the iMP version and try it
