IMP 10.5.1 chat issue
Anas Abueideh
Level 9
Level 9
Dear Colleagues,
We have CUCM 10.5 and IMP 10.5.1. we are using Jabber windows version 10.5 also.
We have chat issue, when we open the chat menu it shows error message "message can't be delivered"
I have noticed that users can't see each other online. I think this is the source of the problem.
CUCM is integrated with AD.
do you have any idea why this is happening ?
Thank you in advance
Anas
Manish Gogna
Hi Anas,
I would suggest verifying your IM&P , CUCM and Jabber config as per the Jabber deployment guide below
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_6/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and-installation-guide/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and_chapter_0100.html
If the issue persists you can get back to the forum.
Manish
Hi Manish,
we are following the guide to configure IMP and Jabber. the chat is only not working.
As I mentioned, the user can't the others online. when you open the chat window to send message, it give an error "message can't be delivered"
Anas
Hi Anas,
If the jabber clients are unable to see the presence status of others then some configuration could be missing or incorrect. Try restarting the Presence nodes , if the issue persists you should collect the Jabber problem report to check for any errors.
Manish
