The upgrade docs say that issuing the command "utils iothrottle disable" can decrease upgrade times. But after the upgrade is complete, you should re-enable I/O throttling.
What are the downsides to having I/O Throttling permanently disabled?
GTG
Please rate all helpful posts.
